netdomain Posted January 3, 2007 Report Posted January 3, 2007 Hi all, Does anyone know how to see data files in Mitsubishi plcs? for example in AB, you can see a list of Binary B3 files, N7 Integer files, F8 floating point files... and inside those we can monitor the data. I was able to use "Entry Data Monitor" but I had to manually put every address. Is it possible just to see it all without entering anything? Like in AB plc? Quote
Gambit Posted January 3, 2007 Report Posted January 3, 2007 (edited) Hi Netdomain, If you're using GX Developer just use the Device Batch monitoring function than you only have to put in the first adres. If you're using GX IEC Developer you can make you're own monitoring files from within the software or Excel. Edited January 3, 2007 by Gambit Quote
netdomain Posted January 3, 2007 Author Report Posted January 3, 2007 I am using GX Developer. Not the IEC version. Thanks Quote
netdomain Posted January 3, 2007 Author Report Posted January 3, 2007 Thanks Gambit, the Batch Monitor worked :) Quote
