gruntstripe Posted January 7, 2007 Report Posted January 7, 2007 Hi, Hope the New Year has got off to a good start for everyone. How do I drive a 7 segment display? There is an instruction in S7 Microwin but I can't find anything in S7 lite, with which I have little experience yet. Thanks in advance, gs Quote
jacekd Posted January 8, 2007 Report Posted January 8, 2007 I have no idea if together with Step7 Lite comes also TI-S7 converter and its library, but if it does then install it. Then you can find FC93 "SEG" in libraries. If not then you can always DIY. Quote
khekd Posted January 10, 2007 Report Posted January 10, 2007 The TI-S7 library does exist in the lite package see the attached snapshot. Good luck Quote
gruntstripe Posted January 25, 2007 Author Report Posted January 25, 2007 (edited) Hello, Thanks for your replies. I'm a bit thick - how do I make this FC work? Thanks in advance, gs Edited January 25, 2007 by gruntstripe Quote
