Ghettofreeryder Posted January 11, 2007 Report Posted January 11, 2007 Hi Guys.. Im new to the Siemens world. Is there a good tutorial site for starting a siemens program? I have figured out how to add symbols and hardware... but how do i actually write the program? Is it ll in the FB/FC? I cant seem to access my I/O symbols. Im quie familiar with programming AB/ScadaPak/GE/DeltaV, but this is far out for me? Any help would be appreciated Quote
khekd Posted January 12, 2007 Report Posted January 12, 2007 Try this website. It is one I found just messing around and dug it up. It is supposed to be for educational institutions but has some great material. Also, when you purchased your Step7 software there should have been a disk in it called Step7 Step by Step. If it is not you can ask your local Siemens distributor to get you one. Good luck, Khek http://www.automation.siemens.com/fea/html...down_module.htm Quote
