good morning friends i´ve a big problem , i upload a program from A1scpu with gx developer 6 , after edit somes lines and download the program, the program do not work, after check the program i observe that , when i upload the program , for some motive i only stay with a part of the program, with 14 outputs when should be 62 outputs. why that happens? after that i find the person who did the original program and he give me the program and said to use a melsec medoc plus or IEC developer , because he don´t remenber wich software use to do the program. how can i know which program should use? i have the gx iec developer v4.00 when try to open this error is displayed: "unable to open the project database with the current version of gx iec dveloper (4.00.00) (the project has been created with the newer version 6.01.06.)" whith melsec medoc plus 2.40 when try to open this error is displayed : "The project has a newer version than your softcontrol 2.04.01. Use at least Softcontrol Version 4.00.00 to open this project." what should i do? this is mi first job with mitsubishi, normally i work with omron and siemens. thanks for help , sorry my english !!
Hi, The GX IEC Developer version he used was 6. So you need to update your GX IEC Developer software. The upload you made with GX Developer should also word though. The problem with seing only some of the lines has to do with the IL Ladder converter. The laddder vieuw is limited to a certain amount of line. When you look at it in IL you can see the rest. You can alwayd recreate the previuos condition just before the last line viewed or set a bit deice which will trigger the rest of the outputs. That way you can see the rest in ladder view Edited by Gambit
What do you actually mean by that, has the PLC stopped recognising that it has 62 outputs? If you uploaded the programme from the PLC in GX Developer, you would probably only see lines of code, with no names or comments. As long as you edited the code correctly, then downloaded the code into the PLC again, then it "should" work. I'm just a bit worried that there are some parameter issues here ... any chance of posting or E-Mailing the IEC project, then we can have a look at it?
