manav Posted January 12, 2007 Report Posted January 12, 2007 Hi, Was unable to log onto mrplc.com for last 3 days. Get the following error: Error 407, Forbidden access to server. Has anyone else had the same problem logging in?
rpraveenkum Posted January 12, 2007 Report Posted January 12, 2007 I had the problem on 01/11/07 at 9.00am to 11.30am for logging into the mrplc.com
rpraveenkum Posted January 12, 2007 Report Posted January 12, 2007 manav post you general quries here http://forums.mrplc.com/index.php?showforum=27 May be some maintenance of the site
BobLfoot Posted January 12, 2007 Report Posted January 12, 2007 Most likely Chako was doing an update of some sort. He usually does these between 12 and 3 am US Time. Unfortunately for those on the other side of the world this is the middle of the day. I've seen it come back in an hour or two in most cases.
jimdi4 Posted January 12, 2007 Report Posted January 12, 2007 (edited) I can only use the fast reply, the "add reply" doesn't work for either one of the "Add Reply" or "Reply" buttons, The text box opens and the reply shows up in quotes with brackets but you cannot type any text...You can add smilies but no text...Why??? Chaco any ideas???? Edited January 12, 2007 by jimdi4
TimWilborne Posted January 12, 2007 Report Posted January 12, 2007 Can you post your operating system and browser, name and version for Chakorules?
jimdi4 Posted January 12, 2007 Report Posted January 12, 2007 Operating system : Windows 2000 Browser - IE - Version 6.0.2800.1106
pseudoquas Posted January 13, 2007 Report Posted January 13, 2007 Hmm...seems there must be something about Lithuania and India...
Ken Moore Posted January 13, 2007 Report Posted January 13, 2007 Are you sure about not being able to type. When I open a text box sometimes there isn't a cursor in the beginning, but if I just start typing, the cursor appears.
jimdi4 Posted January 15, 2007 Report Posted January 15, 2007 [Are you sure about not being able to type. When I open a text box sometimes there isn't a cursor in the beginning, but if I just start typing, the cursor appears].... ....Absolutley, at first I thought the text color was set to white and that maybe was the reason I couldn't see the text, so I changed that, but It almost seems like my keyboard doesn't even work in the "add reply" mode....I am only allowed to reply by selecting the "fast reply" button....problem is, I have to select quotes and may forget to do that, making replies, less legible....
jimdi4 Posted January 18, 2007 Report Posted January 18, 2007 (edited) Ok...sorry about the delay but I fixed it now....Turns out the Rich Text Format had to be turned off in my setup,,,Sorry Chako, my fault!!! Everthing works now... "GO BEARS" Edited January 18, 2007 by jimdi4
