stl Posted January 17, 2007 Report Posted January 17, 2007 Hi, Is it possible to move %I or %Q values to memory more than a bit at a time? so instead of this (one bit at a time) %I1.0 %MW50:X0 ---| |----------( ) %I1.1 %MW50:X1 ---| |----------( ) I've tried using the Operate instruction with the following code added: %MW50:15:= %i1.0:15 to move the status of %I1.0 to 1.15 to %MW50:X0 to X15, But i get a incompatable data type error? Can it be done 16 bits at a time? Either in LAD,ST,IL Hopefully someone can shed some light on this? Thanks Steve Quote
stl Posted January 17, 2007 Author Report Posted January 17, 2007 For anyone who's interested? Operate block Syntax: %MW50:=%I1.0:16 Quote
rajsiyer Posted January 18, 2007 Report Posted January 18, 2007 Hi STL You'd be better off doing %Mw50:=%iw1.0 in that operate block. This is all too commonly required as Modbus does not take direct addressing of I/O's. Perhaps you are right, please check up the bit table syntax in PL-7 help. The Colon notation denotes a bit table. Regards, best wishes Raj S. Iyer Quote
Prashant Yelattiwar Posted February 21, 2007 Report Posted February 21, 2007 hi I've tried the Operate instruction %MW50:= %i1.0:16 to move the status of %I1.0 to 1.15 to %MW50:X0 to X:15, and it's working. regards prahant Quote
rajsiyer Posted June 20, 2008 Report Posted June 20, 2008 Prashant, Hi... Hello steve & STL How do you do this in unity-Pro? Kindly look up my question in this forum. I'd seriously appreciate help Regards, best wishes, Raj S. Iyer Quote
tragically1969 Posted June 23, 2008 Report Posted June 23, 2008 See my reply to your new thread Quote
