Hi all, I'm trying to implement an GPRS connection with siemens MC35i modem to do that i'm using a librarie from Siemens (attached file) wich is very simple to use but i have no control of the connection i don't know the protocol to establish the GPRS connection and i'm having some problems with SIM cards that have dinamic IP.... the librarie is bloked so i can't see the code implemented in order to understand the protocol. I already looked in the Internet for the protocol to establish an GPRS connection i used HyperTerminal but some commands just doesn't work i get ERROR ... Is there any way to unlock the librarie so i can change the protocol and understand it? Thanks all set19_wdm_v1d3.zip
