Have several Series 5 CPU's that I support. Have an older laptop running at 266mhz running LM5 under Win98. Runs fine except can't stay connected for more than a couple of minutes. Believe its the processor speed. Any Clues? Had a really old laptop operating around 100mhz that worked fine until it died and was ceremonially laid to rest. Would not have expected the 266 unit to cause any problems. Also, what software is used to connect to a 90-70? Any help appreciated!!! Thanks, bob
If you are right this should fix it. moslow_v132.zip The current software is called 'Proficy Machine Edition Professional'. You can get information here: http://globalcare.gefanuc.com/ Other older packages are: LogicMaster 90-70 (DOS) Cimplicity Control (I'd stay away from this one) VersaPro Professional (Windows software but "old")
