bjclem Posted January 24, 2007 Report Posted January 24, 2007 TIMER QUESTION , HOW DO YOU PROGRAM A TMR IF YOU USE A k10 THAT WOULD BE A TIMER OF 1 SECOND RIGHT, AND WHERE DO YOU SEE THE ACC VALUE. Quote
rlp122 Posted January 24, 2007 Report Posted January 24, 2007 The accumulated values will be TAx, where x is the number of the timer. For timer T0 the accumulated value will be TA0. For a TMR, yes, K10 would be 1 second. To make the timer variable, place a v-memory address such as V2000 in place of the k10. This would allow you to put the timer preset into V2000 and use a HMI or other means to change it. Quote
s7xp.com Posted March 3, 2007 Report Posted March 3, 2007 Be aware of the fact that the TMRF function is using 2 timers. E.g. T100 is using T100 and T101. Quote
