Cyril zhao Posted February 1, 2007 Report Posted February 1, 2007 Is there the software that can simulate the site environment and product process to help us test our PLC program?Please introduce to me,thanks a lot. Quote
BobLfoot Posted February 1, 2007 Report Posted February 1, 2007 The short answer is YES. The long answer is that it depends. You will need to supply more information, like whose PLC, Whose HMI what SCADA and etc for an accurate answer. You might also want to post the question in the forum dedicated to the brand of PLC you are using. Quote
rpraveenkum Posted February 1, 2007 Report Posted February 1, 2007 Rockwell has RsTest stand http://literature.rockwellautomation.com/i...gr003_-en-p.pdf Quote
Cyril zhao Posted February 1, 2007 Author Report Posted February 1, 2007 I want the software to test all PLC not only specify PLC. Quote
Cyril zhao Posted February 1, 2007 Author Report Posted February 1, 2007 RSTest is Arena? I can't find this software in software direcoty of www.AB.com. Quote
rpraveenkum Posted February 1, 2007 Report Posted February 1, 2007 compliant with OPC so I hope it has to suite all PLC Quote
rpraveenkum Posted February 1, 2007 Report Posted February 1, 2007 Arena is a simulation software no where related with PLC It used to similate the machine operation for example Quote
Cyril zhao Posted February 2, 2007 Author Report Posted February 2, 2007 Why don't Rockwell list the RSTest at software directory? Quote
