scottmurphy Posted February 7, 2007 Report Posted February 7, 2007 This may have been fixed in latest version of CX-D, but could not find if it was on the improvements requests. It could also be something that I have set incorrectly. When switching between CX-D projects, the comm setting seems to remember the last project that it connected to, not related to the current project that is open. So if I have project 1 that is serial, and I open project 2 that is ethernet, and I previously connected on project 1, when I go to connect to project 2, then I need to update the comms method settings. The same applies for 2 projects with differing IP addresses. Has this issue been corrected in the latest version, I am currently using V1.013.
ParaffinPower Posted February 8, 2007 Report Posted February 8, 2007 Hi Scott I'm using 2.02, and it still seems to remember the last transfer settings. Pp
tashinz Posted February 12, 2007 Report Posted February 12, 2007 Yep, the connection settings are not remembered in project. regards
scottmurphy Posted February 13, 2007 Author Report Posted February 13, 2007 I mis-read paraffins post, I thought that it was corrected, but after reading tashinz reply, this issue is still there. Does everyone agree that this should be corrected, so that the settings are remembered for each project. I had this situation again today, had to change all my settings to suit.
tashinz Posted February 13, 2007 Report Posted February 13, 2007 Yes, I am using CX-D 2.02 also, and transfer settings are not remember in the project. I think it is better to remember this inside the project, like in CX-Programmer. regards
