FRS500 AC Drive on Communication
I am using 20nos. S500 AC drive and writing frequency through Rs485 Communication. My parameters are P.79 =0 n8 =1, inverter starts/stops from external terminals n9 =0, Frequency write via communication n10=1, Communication start Since the drive is in communication it always accepts frequency from communication, now in any case if computer communication cable fails, an auto/manual switch is moved to manual and drive should take frequency from internal POT or through external terminals. I have read the FRS500 Detailed instruction manual and found nothing about switching a mode. However i have attached a page of manual where it says if p79=0 & n10 =1, Computer link is Disabled when PU is selected &Enabled when external is selected, but there it is not mentioned that how to select PU or External. I have tried with X16 Signal but no results. Since Plant is continuous switch over should be fast. Parameter_Details.pdf
