Hi, I have genius versamax devices in a bus. I download the configuration successfully (no errors), i set the correct SBA and although the fault led lights. I tried several NIUs and modules (DI, DQ, AI, AQ), but i have the same problem. I have no bus problems. Are there any specific steps i have to follow for the downloading? I use: SLOT 0 GBI0001 SLOT 1 DI MDL640 SLOT 2 DI MDL640
The main things are that the bus is properly wired and terminated and that the hardware configuration of each I/O device "EXACTLY" matches the Bus Controller hardware configuration. This includes any diagnostic data. Make sure that all I/O modules and NIU are properly powered. Double check your carriers and modules for bent pins etc. Also there seems to be too many DOA carriers.
