Hello guys, I am thankful that there are people like you to help peoplelike me who are learning PLC programming. I need help with what is probably simple logic for most, but frustrating for me to figure out. I am using a S7-200 micrologic plc and I want to be able to turn on and off my conveyor section with the same push button input. I can get it to latch using a set bit but I am not sure how to unlatch it by using the reset bit. Can someone show me the logic for turning on and off 1 output using 1 input which is a momentary push button. Thank you in advance. Edited by mr_electrician
Use a MW as integer. On the rising edge of the input increase the integer with 1. In case the integer >=2 then integer =0 If integer = 0 then output =0 If integer = 1 then output =1 Or use a pulse with bit logic, otherwise you are in a loop. Good luck
Look at this thread. http://www.plctalk.com/qanda/showthread.ph...ighlight=toggle My simple solution is post 37, there are a few ways listed though.
Thanks Groo, that will help as well. I will give it a try just for practice, as well in my future programs. You guys ROCK! Ilook forward to learning lots from you guys. Hope you don mind getting bombarded with what might seem like simple logic to some of you guys.
One more thing you can do is to use a counter. One push of the button can move bit 1 in the counter (use logic ... if count value is one ...it is ON )next push adds one more and if the count value is 2 reset counter ( this is OFF ).. try this it works -Anshuman
