Me again, after one more bit of help for college . Could anybody point me in the right direction for the following. I need to give four functions are, less that, greater than, binary to BCD and PID control. I need to evaluate each of these functions in turn by giveing examples of how each would be used in a ladder logic programs. Also i need to state typical applicications for each advanced function. Regards Dave. Edited by Dave1971
Less Than compares two numbers and returns true when A<B. Surely you can think of a use for that. Greter than compares two numbers and returns true when A>B. Surely you can think of a use for that. Binary to BCD conversions will change a binary number like 0000 1101 0000 0101, which is 3333 decimal, to 0011 0011 0011 0011 which is 3333 in BCD format. Here is some information on the BCD format: http://en.wikipedia.org/wiki/Binary-coded_decimal. Surely you can think of a use for that. PID stands for proportional+integral+derivitave. It is used in closed loop process control for controlling variables such as temperature, flow, level, position, power, pressure, force, velocity, feed rate, tension, etc. Surely you can think of a use for that.
You could look them up in "A Field Guide to Popular PLC Elements" by General Rockwell Mitsumoron, USMC ret. It includes colour pictures of the most frequently encountered elements, male and female, in both juvenile and mature forms. It's available for ordering now at pre-publication pricing at Amazon.com, Borders, Barnes & Noble, and many other online sites. ISBN 1771-314159. The actual publication date is 4/01/2007.
May be we are assuming Dave knows what greater then and Less then mean. Here is a link that should help him put his thinking cap on. http://www.songsforteaching.com/jennyfixma...terlessthan.htm
I find a direct correlation between my age and the frequency of buffer flush interrupts. So far it appears to be simply a linear relationship. If it turns out to be exponential I may have to perform preemptive BFIs. It Depends.
It is definitely exponential. 1st Beer - No Go 2nd Beer - No Go 3rd Beer - No Go 4th Beer - No Go 5th Beer - No Go 6th Beer - Got to Go Go Go!!! 7th Beer - No Go 8th Beer - Gosfdt tasdo Gdfo Gfo Goa!!! 9th Beer - Gsdfot ffwto Gfswdo Gdso Gofds!!! 9th and a half beer - fdslkjg gewdsa awsgkl gwfsd!!! What beer was I on? Hey!!! Look at that hottie at the end of the bar. I'm moving in. Glad that ugly one finally gave up the seat. I think a graph is in order so Peter can examine it
Normally I would like to but in this case I think it is too much information. It was funny though. Are interrupts advance functions? How about beer buffer interrupts? Maybe this requires a poll. TW are you back? I just got back too. Two weeks in Ireland and 5 days in Finland. It is too bad I had to leave Ireland before St Patrick's day. It would be interesting to see how the Irish celebrate St Patricks day. It probably requires many pints of Guinness with many beer buffer interrupt service routines. I wonder if they can put enough food coloring in a Guiness to turn it green. Hmmm. I guess I will never know.
Hmm... dead time approx 6 beers time constant approx 2 more beers not enough info to calculate gain but it seems that something is wound up or saturated.
