I have created a small program for S7-200 to monitor what percentage a machine runs out of an 8 hour shift. Ie, the machine stops and starts many times during the 8 hours and I want to have a "live" percentage displayed on a TD200 unit and also log this to memory at the end of the shift, reset and start again. I was wondering if one of the guru's who visit here would take a look at it for me and maybe tell me where things could be done better as this is the first time I have had to handle data. Or a S7-200 for that matter. Any advice would be greatly appreciated. (This program is only a trial of this idea, once happy with it, I will integrate with another trial I have on the go.) Thanks for reading, I hope it made sense. I will send program to any generous person that offers. Edited by Gazzr
Also, as more of a topic for discussion. What are my options for outputing this information each week? Can the accumulated info be sent as a file somehow? By wire / or wireless would be even better. Anybody have experience with this?
Please post or send direct to me. There is a modem, EM241, for the S7 200 PLC's and also an Ethernet and/or a internet connection. All with set up wizards that you can use to transfer data.
Here is my first attempt at program. Any feedback welcomed, as i am convinced it could be done easier. Especially network 8, which i'm sure need not be there at all, if i knew how to use the data block editor...... I also should mention that i was provided with the Read RTC subroutine. (Many thanks) Percent_log_2mc.rar Edited by Gazzr
Thanks for the info Moggie. Using the modules you mentioned, can the plc be set to automatically transmit a set of data at a given time? And would the recipient computer have to be running specific software. An ideal solution would be to output an excel file or something similar. Can this be done?
There is software (typically an OPC server or ActiveX control) which can be used to retrieve data from a PLC and drop it onto an Excel spreadsheet. Siemens has an OPC Server for the S7-200 called S7-200 PC Access. It will allow you to poll the PLC for data at fixed intervals. Might want to go try to get a catalog or manual on it's capabilities.
