Problem in Factory PMI Gateway Connection
hi.. This is the first time am seeing FactoryPMI,today morning i was downloaded am installed in my pc.once the installation was completed it was connected automatically to the Gateway then i shutdown the application and try to communicate to gateway but its not able to communicate wht may be the problem plz help me regards, Suma
hi suma.. can you please tell me the path from where I can download FACTORY pmi gateway? I can try and tell u..
Sorry, I've been away from the forums here for awhile. You get to the FactoryPMI Gateway by opening the URL from a web browser. By default that would be, http://IP_address:8080. You can set the port in the gateway configuration web page. You can use localhost if you're on the gateway computer and can also use computer name or IP address. You can download an evaluation from here.
