Alex1277 Posted March 18, 2007 Report Posted March 18, 2007 Hi everybody, I haxe FX2-32MT where i can find manual? What is the difference fx2 and fx2c? Thank you! Quote
Crossbow Posted March 18, 2007 Report Posted March 18, 2007 All manuals can be found on www.meau.com in the Downloads section. The difference between the FX2 and the FX2C is the FX2 has terminal block connections, and thre FX2C has high density pin connections designed to be wired to external terminal blocks. Quote
Alex1277 Posted March 22, 2007 Author Report Posted March 22, 2007 Thanks a lot! I could not find any manyals on www.meau.com for FX2 Quote
Crossbow Posted March 23, 2007 Report Posted March 23, 2007 They are there. Here's a link to the FX Series hardware manual that should cover FX2. I found it by typing FX2- into the part number search field in the Downloads section. http://www.meau.com/functions/dms/getfile....000000204701000 You'll also want JY992D48301 which is the programming manual. http://www.meau.com/functions/dms/getfile....000000204800000 Quote
