Scroll up to the top of your ladder logic and select 'Variable Declarations' (or similar) and press F10 (zoom). In the Main block all variables will be global, if you do this in any other block these variables will be local to that block only.
In addition to writing names and nicknames for variables, you can add rung comments by inserting a "COMMENT" instruction. Each comment counts as a rung. Once the comment rung is in place, you move the cursor to it and hit F10 (zoom) to get to where you can write the text. The comment instruction is located in the "CONTRL" menu (SHIFT + F9) when you are editing a rung or adding a new one. Comment text is not visible while you are monitoring a rung, but it can be included in a hardcopy printout.
