TimWilborne Posted March 24, 2007 Report Posted March 24, 2007 I am looking for a way to connect either through the internet or phone to some remote locations, the only catch is that LAN lines are not an option. I have been looking a satellite internet and some cellular services but thought some of the members here may have already been down this road. The bandwidth and connection time requirements are low. Probably log 100 bytes every hour at the max. The only other time there would be a connection is for troubleshooting. Any thoughts? Thanks TW Quote
beegee Posted March 26, 2007 Report Posted March 26, 2007 cellular can be an option if the data is limited. Two drawbacks: you need coveage of the network over there and you can have big delays in the communication. Standard modem on PC side should be no problem I presume. The only thing you have to check is your protocol passing on the line. Some asics have problems with some protocols like 1,7,e,2 9600 (used a lot in Japan) because you have an 11bit frame. Quote
TimWilborne Posted March 27, 2007 Author Report Posted March 27, 2007 I don't think speed will be a problem. Can you think of any solutions besides cellular? Thanks TW Quote
beegee Posted March 27, 2007 Report Posted March 27, 2007 standard modem? If price is not an issue you will probably find solutions with satelite, but for that limited amount of data I don't see a real reason. Quote
TimWilborne Posted March 27, 2007 Author Report Posted March 27, 2007 The problem is the LAN lines are not an option on some of these systems. When they are available they are available we will use VPNs and phone lines but I'm trying to find the best solution for these systems that can't have any type of LAN line Quote
beegee Posted March 27, 2007 Report Posted March 27, 2007 How far are you away from PSTN/Ethernet/Cable/DSL networks? Can you reach one of these networks with a radio modem (limited range depending on the local legislation) Quote
Ken Moore Posted March 27, 2007 Report Posted March 27, 2007 Radio modems are a good choice if there is an outside line within line of sight, range can be upto several miles. The U.S. allows a stronger signal then the EU. 1. Connect a radio modem to field. 2. Connect 2nd radio modem to land line. 3. Dial in or VPN to 2nd modem. Another option would be a GSM modem, would depend on local coverage. I believe you can get plans where you only pay for the minutes on line. Check to see if your area of concern is covered: http://www.gsmworld.com/roaming/gsminfo/index.shtml Quote
TimWilborne Posted March 27, 2007 Author Report Posted March 27, 2007 What is a GSM modem? Edit - Ken, that looks like what I'm looking for. Anyone got any experience going online through them? Any connection problems. If the speed is slow it won't be an issue. Quote
Ken Moore Posted March 27, 2007 Report Posted March 27, 2007 A GSM modem is basically a wireless digital modem that utilizes the cell phone service providers for access. So, if a cell phone works, you can probably use a GSM modem. Not all cell service providers have GSM service, I know Verizon doesn't, but the other major carrier do. I prefer Westermo units: http://www.westermosales.com/gd01.htm I would contact them directly. Modems are around $500 each and the service is going to be 30-40 per month. Quote
TimWilborne Posted March 27, 2007 Author Report Posted March 27, 2007 This might be a stupid question but does it require special hardware or do you pretty much plug a cell phone into it and it require a special GSM service? Quote
Ken Moore Posted March 27, 2007 Report Posted March 27, 2007 Enterton now sells GSM modems with service: http://www.entertron.com/gsmgprsmodem.htm I believe most GSM modems transfer data at fax machine speeds, something along the line of 14.4k baud. NO cell phone required, just connect the plc or other serial device to the modem, uses standard AT commands. Quote
TimWilborne Posted March 27, 2007 Author Report Posted March 27, 2007 Ok thanks Ken, looks like I need to put in a call to Stephen Luft Quote
beegee Posted March 27, 2007 Report Posted March 27, 2007 Wavecom and Siemens also have cellular(GSM) modems. We have had quite good results with Wavecom (price under 200€ , that's 250$) by the way, Wavecom does support 11bit, we used it on OMRON plcs Quote
TimWilborne Posted March 27, 2007 Author Report Posted March 27, 2007 Thanks. I found the Wavecom but can't seem to find the Siemens. Do you have a link? Thanks again TW Quote
beegee Posted March 27, 2007 Report Posted March 27, 2007 Check for Siemens M1, M20 and TC35 in Google for local suppliers (I can give you links but mainly in Europe ) By the way, I thought the wavecom is also with a Siemens M1 chipset Quote
Sleepy Wombat Posted March 27, 2007 Report Posted March 27, 2007 TW when you get the GSM you need to get a SIM card of cause,,, most likely get the SIM card to have DATA calls enabled. Quote
TimWilborne Posted March 28, 2007 Author Report Posted March 28, 2007 Not quite following you Sleepy, can you explain? Thanks TW Quote
Sleepy Wombat Posted March 28, 2007 Report Posted March 28, 2007 Basically what you a getting with a GSM modem is a industrialised mobile phone that talks on the GSM network.... Here in Oz, to get the "mobile phone" to work you need a SIM card (Subscriber Identity Module), as i am sure that this is the case in the states... Now by default your SIM card will be set up for voice/SMS calls... There is another mode called DATA mode available as well (I think that it had more to do with the carrier service provider). I had to specifiy that i wanted this... might be different over there.. but been a while since i had to do this so things might have changed. Quote
beegee Posted March 28, 2007 Report Posted March 28, 2007 In Belgium this is available with each SIM card but not all operators activate the data service by default. You could also consider GPRS or UMTS but I have no experience with those possibilities. Quote
swimmy67 Posted March 28, 2007 Report Posted March 28, 2007 TW, Here is another Cellular Modem that I have been looking at. http://www.multitech.com/PRODUCTS/Families/MultiModemEDGE/ I hope this helps. Quote
504bloke Posted March 29, 2007 Report Posted March 29, 2007 I am currently working on a project that will be using a MultiTech GSM Modem (MTCBA-E) It will be on a remote pumping station for alarm dial out. There is no PLC in the cabinet only some SSD Drives and a Redlion G303, the G303 will be connected to the modem. Quote
TimWilborne Posted March 29, 2007 Author Report Posted March 29, 2007 I'm leaning towards the MultiTech also. Looks like Sprint has a 40mb plan for $39.99 and an Unlimited mb plan for $59.99. 40mb seems like a plenty when your just polling data, no graphics. Think that will be enough? Quote
