I am adding some additional mods to a Micro program and have the following question: How do I insert a column in a parallel branch network, so I can add further conditions. Thanks in advance
In Proficy ME you place the coursor to the left (by default) of where you want the new column and select the menu 'Insert > Column' The default can be changed to insert to the left of the highlight box instead of to the right. Edited by RussB
Here's how to do it in Logicmaster. Move the cursor to the rung you want to modify. Press F2 (edit) to begin editing the rung. Then press <SHIFT> + F10 (opn sp). Once you do that, move the cursor to where you want to add the column and hit F1 (mov rt). The element that the cursor is on will be pushed one place to the right each time you hit F1. The F3 key in the same menu is labeled "mov dn" (move down). The F5 key is "del cn" (delete column". The F7 key is "del rw" (delete row).
Found it, from the edit menu you press shift F10 OPN SP, you then get another menu where you can add rows, columns etc. Knew it would be there, somewhere! You just beat me there Steve with your answer, thanks Edited by ratcliffe_ic
