Dear All, Anybody that have experience in using Profibus DP configurator software to download directly into the AJ71PB92. What is the cable we should use to connect at the Profibus module DB9 port? Thanks & best regards, Steve
Hi Steve, I have attachted the file with the layout to this message. To acces the card directly you need GX Configurator DP 4 and I think it's also still possible with version 5. In later versions it's only possible through the CPU. Regards, Berry Tessel Mitsubishi_Proficab_Wiring_Diagram__2002_.pdf
Hi,
Can you reshare the profibus interface cable pin outs please - i know its an old thread. Im using profimap V2, its used to be a blue lead supplied by mitsi back in the day - i need to make one as have a failed drive...
Thanks
2 hours ago, Cartman said:
Hi,
Thanks
Usually Blue cable is for Profibus PA and the magenta coloured cable is Profibus DP. Below is the standard pinout of Profibus DP.
Hi Hati,
Thanks for the reply but I need to make a comms lead up to communicate with the A1SJ71PB92D card rather than the actual profibus connections.
Thanks
Dave
