Hi, I have a westermo gdw-11 gsm modem. I have used this modem to connect to a remote computer using pc anywhere. My latest application is giving me problems where windows xp will not communicate with the modem. I installed the modem as before and i can query the modem from the properties window. The modem is installed on com 2 (serial Port). When i set up my host in pc anywhere an error message comes up every time "error initilising modem". I have all my port settings set up the same as the previous computer that is working with this modem. Dell cannot tell me a rason for it nor can westermo. Can any one give me any clues as to how to solve it. Thanx
Try removing the modem from the device manager and have it re-detected as new hardware by doing a reboot or scan for hardware changes. Perhaps do the same while using COM1 ?
Also try uninstalling before re-installing the modem and re-installing pcAnywhere after the modem has been installed
