mulderm Posted April 30, 2007 Report Posted April 30, 2007 Hello, I want to connected the Siemens OP73 to the Siemens S7-200 plc so that I can also put the programming cable to it. I using the Profibus adapter 6ES7 972-0BB41-0XA0 but how are the connections from the OP73 to this adapter? From the manual I must using a MPI-network but how are the cables connected? Greetings, mulderm Quote
