BobB Posted April 30, 2007 Report Posted April 30, 2007 I am sure you will all enjoy this switchboard. It is running a swimming pool!!! Not even an RCD in site and an absolutely top class installation!!! Pretty obvious why the fire extinguisher has been provided and I just love where they have run the liquid chlorine pipes!!! Quote
TConnolly Posted May 1, 2007 Report Posted May 1, 2007 Are those contactors just hanging out in space or are they just screwed down crooked? You should add those to the gallery. Quote
Sleepy Wombat Posted May 1, 2007 Report Posted May 1, 2007 The boards were probably installed by a simliar electrician like below.. Quote
BobB Posted May 1, 2007 Author Report Posted May 1, 2007 I was not game to get close enough to find out. The plant is still running. By the way, did you like the resistors for the old primary resistance starter? At least they were mounted high up so as not too overheat everything in the panel. Seen that done before Sleepy and even worse. Saw one guy connecting stuff live in a thunderstorm with a tea towel over the connections to stop MOST of the water hitting the terminations. Quote
robh Posted May 1, 2007 Report Posted May 1, 2007 I like the way some of the conduit is coming in to the top of the box, looks like they just stuffed the conduit in a hole. Quote
Sleepy Wombat Posted May 2, 2007 Report Posted May 2, 2007 Why even use flex conduit when you could simply pop 3 core orange flex straight in.. argh! Quote
TConnolly Posted May 2, 2007 Report Posted May 2, 2007 It looks like that is the only part that is original OEM - the wires are straight and the bends are sharp 90s. Everything else has been kludged later. Quote
robh Posted May 2, 2007 Report Posted May 2, 2007 (edited) I almost missed the duct tape used to cover up an old switch or push button hole. At least the other switches are labeled! Edited May 2, 2007 by robh Quote
PdL Posted May 2, 2007 Report Posted May 2, 2007 Still I think I would have less problems with it then our washing machine LOL Quote
OIDMBTRTECH Posted May 3, 2007 Report Posted May 3, 2007 That looks more like the scrap wire bin at a shop where I used to work. Quote
TConnolly Posted May 4, 2007 Report Posted May 4, 2007 That duct taped hole just happens to be the best sealed up part of the panel. Quote
gravitar Posted May 5, 2007 Report Posted May 5, 2007 And let me guess.. whoever owns that lovely system doesn't see any reason to spend any $$ on improvements because it's "working".. Quote
