Hi ! Mostly I do with Omron but recently I got machine with PLC TSX as mentioned in title (propably made in 1991) It has EEPROM card and it is in STOP mode. How I can switch to run mode. Do I need any soft and what cable I need to connect with laptop. Thanks for clue. Pawel
TSX17 had a run switch didn't it? It's been so long since I've seen one. The cable had converter electronics in it, it's not easy to make one. I think the old part number was TSXACC8 or TSX17ACC8 or something like that. These things are long obsolete. The software was a really old and dificult DOS based package.
It does not have any switch. I think I can make run mode from the soft as it is in Omron. I arranged cable with converter and PL7-2 soft. Soon I will try to connect it. Thanks Pawel
