waynes Posted June 4, 2007 Report Posted June 4, 2007 Hi guys/ gals, Relatively long time ago worked with Siemens. Question: Does anybody have a working example/ suggestions for sending SMS's using the MC35 module. I have a S7300-2D CPU and CP341 comms module. Any suggestions. Quote
JesperMP Posted June 4, 2007 Report Posted June 4, 2007 Hi Waynes. There is no exact manual or FAQ for the combination S7+CP341 and an MC35. Maybe these links can help you: http://www.tdc.co.uk/technical/downloads/faq/faq-09-01.pdf http://www.mobiledata.com.au/content/kb.asp Looks like you have to send AT commands to the MC35. That should be doable with the CP341. Actually for ASCII comms, a CP340 would have been enough. Quote
waynes Posted June 6, 2007 Author Report Posted June 6, 2007 Thanks JesperMP, having a look at it now. Quote
