Guest nuttaphong Posted June 16, 2007 Report Posted June 16, 2007 Hi All, I am looking for some help, on writing a logic to control the Power output from a VFD using PID... I will appreciate your help. FX1S-30MR-ES/UL Quote
Paul Ked Posted June 16, 2007 Report Posted June 16, 2007 The programming manual can be found here: http://forums.mrplc.com/index.php?autocom=downloads&showfile=693 The manual explains the PID function and gives you an example. I've never used PID in the FX1S but from Points to note in the manual it says that you need RS232 communications to achieve basic PID operation. Additional PID functions (like the very handy Auto Tune) are not available in the FX1S either. Good luck! Paul Ked Quote
