Guest pdcsah5 Posted November 6, 2003 Report Posted November 6, 2003 Is there any drivers that is needed for the wonderware to communicate to the siemens s7-315-2dp. I am using a ethernet between the process and the pc. Quote
Guest Fritz_frederix Posted November 6, 2003 Report Posted November 6, 2003 Hi, Yes you need a driver and it's on the IO servers cd which you received togheter with your Intouch CD. I also have an excell sheet with all the soft-hardware you need to connect Intouch with a Siemens PLC. Just mail me your email adress and I well send it to you. I used a CP 343-1 industrial ethernetcard in my PLC and used an CP1613 industrial ethernet card in my PC (I was working with WinCC). Some guys of wonderware told me that it also works with Intouch. I used to connect Sè PLC's with Intouch but I used an applicom card rather expensive tough. Hope this helps Rudi Quote
