Husanto Posted June 22, 2007 Report Posted June 22, 2007 Hi guys, i'm a new member in this forum. i have a problem about using the serial communication. can any body help me. I have a PLC Q series ( Q02HCPU), master station(AJ65BT11N) and serial communication (AJ65BT-R2). I try to using this device with reading from manual book but i can't operate that device. So, can any body help me how to use this CCLink Device ( sample program, setting or step by step to use AJ65BT-R2)?? Thanx... Quote
panic mode Posted June 22, 2007 Report Posted June 22, 2007 For Q series CPU, CC-Link master part number is QJ65BT11N... I just placed some PDF file in http://forums.mrplc.com/index.php?dlcategory=17 See if this helps... Quote
Husanto Posted June 23, 2007 Author Report Posted June 23, 2007 Ok I already try to set up all cclink parameters but i can't be done to communicated serial comm to external devices ( Computers ). So, can i got one a completed example programs that's i can truly use it. thanks for ur help. Need Ur Help immediately... regards, Husanto Quote
Crossbow Posted June 24, 2007 Report Posted June 24, 2007 Actually the master is QJ61BT11N. And read the map of memories in the manual to see what needs to be configured to control the module. I don't have an example program to share. Also, I know when upgrading from the A Series to the Q Series, you cannot use AJ65BT-R2, it has to be the latest version AJ65BT-R2-S3. Perhaps the module you have is not the R3 revision and will not work on the Q series. Quote
Husanto Posted June 25, 2007 Author Report Posted June 25, 2007 But i read from the manual AJ65BT- R2 can support the Q series PLC. i very - very Quote
luis137 Posted October 25, 2007 Report Posted October 25, 2007 this part is only to know if you have a sucesful comunication with the CPU. and for this code the net mudule is conected in the 4th slot. whit 23 modules ok so you can use for less modules. cc_link_sample.zip 1 Quote
