Hi there. I'm using an Hakko v712. I want to change colours of a pump using 2 bits. the first is "alarm" and the second is "pump running" if both the bits are off the pump will be grey. if the first is on pump will be red if the second bit is on the pump will be green. how can i do that? ive see that with a lamp memory i have more then one colour avayable but i can use it only referred to a bit any idea? thanks
