arsenen8 Posted August 19, 2007 Report Posted August 19, 2007 Hi all, I have a problem why my plc cannot run? Is it the RUN terminal in the plc need to connect to any thing? Please advise. Thankyou Quote
Crossbow Posted August 19, 2007 Report Posted August 19, 2007 There are 2 RUN terminals. You put the PLC in run mode by closing a switch between those two contacts. Quote
arsenen8 Posted August 19, 2007 Author Report Posted August 19, 2007 Sorry. There is only one RUN terminal. other terminal near there is 24V=2 terminals, 0V=2 terminals, S/S=1 terminal. May i know which terminal should i short? Quote
hculyer Posted August 19, 2007 Report Posted August 19, 2007 (edited) As I recall, you need to connect 24VDC to the run terminal. To download the program from your PC to the PLC you need to disconnect the 24VDC from the run terminal. Be sure to double check the hardware manual first. I cannot find mine. Good Luck, hculyer Edited August 19, 2007 by hculyer Quote
arsenen8 Posted August 19, 2007 Author Report Posted August 19, 2007 OK. The plc is RUN now. But after a few second, the RUN led is OFF and the CPU-E led is ON (red color). May i know what is this error? How to check the error? Please advise. Thankyou. Quote
hculyer Posted August 19, 2007 Report Posted August 19, 2007 (edited) arsenen8 You need to go online with you PC to the PLC. Read D8004 it will have an error code number. This number will relate to the error detection devices in the plc. For example: in D8004 you read 8060, this relates to M8060 which is an I/O configuration error. Whatever number you get look in the FX programming manual section 6.7. This manual is in the downloads section of this forum I do believe. Keep us informed of your progress. Edited August 19, 2007 by hculyer Quote
arsenen8 Posted August 20, 2007 Author Report Posted August 20, 2007 Please attach the manual book here. Thankyou. Quote
Paul Ked Posted August 20, 2007 Report Posted August 20, 2007 http://forums.mrplc.com/index.php?autocom=downloads&showfile=508 Quote
