Fx2n + got900 download program question
Hi, i littel question: i've a system composed by a PLC Mitsubishi FX2N + a Touch Screen GOT940 connected. The question: i've made a progam with GX Developer for the PLC and a program for the GOT940 with FX-PCS-du-win-e . Can i upload the 2 program(one for the PLC and the other for the GOT) from the RS232 port on the GOT with a normal 232-232 cable? Or i must before upload the program made with GX to the PLC(with a SC-09 cable) and then upload the program made with FX-PCS-DU-WIN-E to the GOT with a normal 232-232 cable? Thnks for any help
You can program the PLC through the GOT connection. So plug the programming cable into the GOT, and download from both programs (but not at the same time obviously).
Thanks! So before i use GX Developer and i download the program to PLC. Then vwth FX-PCS-du-win-e i download the program to GOT,always using the 232 connector of the GOT. It is OK? Thanks Ciao MAX
