V. Sinisalo Posted September 5, 2007 Report Posted September 5, 2007 Hello, i have Mitsubishi Melsec FX0-30MR PLC and i tried few cable settings before i got SC09. Everything else is okay, but the PLC blinks the green power on light as soons i put the power on. Is there anything to know... i have only attached the 220v and nothing else?
Gambit Posted September 5, 2007 Report Posted September 5, 2007 (edited) There is probably no program in the CPU. Can you acces the PLC with your software? Edited September 5, 2007 by Gambit
Crossbow Posted September 6, 2007 Report Posted September 6, 2007 Power light blinking tends to be hardware problem or overload on the built in 24VDC supply. Disconnect all extension modules, unconnect any wires on the 24VDC supply, and see if the problem goes away. If not, it probably needs to be sent in for repair.
