NickO Posted September 11, 2007 Report Posted September 11, 2007 (edited) Hi guys, we have just upgraded to Citect v6.10, and after three weeks it has been noticed that some trends are showing erroneous data. """Please note further investigation has revealed that the upgrade is not to blame, as this problem has been with the system for over a year.""" For example a speed trend taken every 30 secs will have data missing every so often, so instead of a full curve you have missing parts to the curve. Has anyone else had this problem ? If so have you a simple cure. """It would seem that the data collected is incorrect, maybe caused by the settings in Citect taking the value out of the Omron PLC""" """But still if anyone has experience of this I would appreciate any help"" Cheers Nick Edited September 11, 2007 by NickO
PdL Posted September 11, 2007 Report Posted September 11, 2007 There could be various reasons for this. Do you have the Citect Knowledge base ? You can download it if you register at www.citect.com. Attatched are some articles that might be of help. How many trend tags do you have ? What is the sample period and no. of files (default is 2) you have set for your tags ? How many files are there in your citect data directory ? Q3182_Gaps_in_trends.pdf Q3793_Trend_gaps__slow_IO_and_page_updates_caused_by_Anti_Virus_software.pdf Q3852_I_have_gaps_in_all_my_trends_when_only_one_PLC_is_offline.pdf
NickO Posted September 27, 2007 Author Report Posted September 27, 2007 Further investigation revealed that this was due to error in the PLC and not Citect at all
