luis137 Posted October 26, 2007 Report Posted October 26, 2007 i use the Q06CPU & I HAVE M0-8191 THE QUESTION IS IF A HAVE A GROUP OF M, LIKE A M2000 TO M2099 I CAN USE THIS GROUP LIKE A WORD I MAKE OPERATIONS WITH WORDS? Quote
Gambit Posted October 26, 2007 Report Posted October 26, 2007 (edited) Yes, you can take multiple bits and use like a nibble byte or word operation. You achieve this by putting a K.. value for the bit device For instance: K1M2001 - M2001 - M2004 K2M2001 - M2001 - M2008 K3M2001 - M2001 - M2012 K4M2001 - M2001 - M2016 If you use these in D instructions or Batch instructions more Bit will be used. For instance: BMOV K4M2001 D1 K10 This will mov the bits M2001-M2160 to D1-D10 Edited October 26, 2007 by panic mode Quote
