Renato Posted October 26, 2007 Report Posted October 26, 2007 Hello I have Step 7 software installed on a Virtual PC and I'm having problems to access/use the CP5512 PCMCIA profibus card from Siemens. On the host pc I have no simens software installed. Does anywone had the solution for this problem. Thank you for your help. Regards, Renato. Quote
gruntstripe Posted October 27, 2007 Report Posted October 27, 2007 Hi, It's not possible. You cannot access this hardware item from a virtual pc because virtual pc's only use virtual hardware! Quote
