I found this and thought I pass it along. You can view/edit drawings that were created in a new version of AutoCAD with an older version of ACAD. I use 2008 at work but 2002 at home and all seems to be working fine so far. http://www.dwggateway.com/
Bob, Thanks for the link. Leave it to Solid Works to help out with a revision level converter for AutoCad. OT: I tease the 3D Mechanical Engineers that all I have to draw is circle, squares, straight lines and all on snap!! Bud
