Nibroc Posted October 29, 2007 Report Posted October 29, 2007 Hi, I was wondering if there is an easy way to reuse a common pop-up panel. I have an application where need 50 or so pop-up panels. Each is the same, however references different PLC addresses. In other applications I have been able to simply do a 'search/replace', and simply replaced the unique part of a structured tag name for all instances within a particular 'panel', however it appears this cannot be done with Vijeo. Is there a method via the 'toolbox' or similar ... Thanks in advance ... Nibroc
Nibroc Posted November 1, 2007 Author Report Posted November 1, 2007 Hi, To answer my own question, yes you can re-use 'standard popups' simply by implementing dynamic addressing - should have looked for this feature earlier! Nibroc
