Davo Posted November 7, 2007 Report Posted November 7, 2007 Hi. I just took a Siemens class, but I can't find an answer in my book... or online. I have an S7-200 224XP with 10 discrete outputs, but I need 12. It seems like I should be able to send current through the analog ports to energize 24VDC relays. Can this be done? How, please?
Crossbow Posted November 8, 2007 Report Posted November 8, 2007 Obviously didn't pay much attention in class. Analog inputs and discrete inputs are 2 completely different things. You can't just send current through the analog to make it turn on. For another thing, the analog inputs on that unit are voltage only (-10 to +10 volts DC). Analog inputs are variable signals, not on/off relays. Buy an I/O extension block.
Davo Posted November 8, 2007 Author Report Posted November 8, 2007 (edited) Thanks, I get that... but why can't I vary it from 0 to "full"? If there's not enough voltage to power a relay, that's a different problem - we can use 5VDC relays if needed. Edited November 8, 2007 by Davo
Crossbow Posted November 8, 2007 Report Posted November 8, 2007 You can't power a relay from an analog output. Buy the extension block. The analog output is not designed to carry a load like a relay coil.
