sparkotronic Posted November 13, 2007 Report Posted November 13, 2007 Hi all, I'm looking for a bit of advice. I've been asked to put a control system in place to regulate the heating in one of our production halls. I have previously installed a compressed air managment system and I want to integrate it in to this panel. I'm not sure what to use for the feedback of zone tempretures. My manager wants each zone temp to be displayed on a HMI and also to have set point adjustments on the HMI. I'm ok with the programming side, I just not to sure whaich type of temp sensors to use. Should feedback be 4-20mA/0-10V? Each zone is about 50-100 meters away from the control panel. I see that Siemens supply Tempreature control modules for the 300 range of PLC's, would this be the best way to go? Thanks in advance, Colin Quote
JesperMP Posted November 14, 2007 Report Posted November 14, 2007 Avoid 0-10V. The widely used industry standard is 4-20 mA. A distance of 100 m is no problem with a 4-20 mA sensor. For temperature measurement, the alternative could be Pt100 sensors going into dedicated Pt100 analog inputs. You need to pull all 4 wires the whole way to the sensor to facilitate the wire compensation. The use of 4-wire cables means that this option is actually more expensive than 4-20 mA. Quote
sparkotronic Posted November 14, 2007 Author Report Posted November 14, 2007 Thanks for the advice, I'll need to have a look at some sensors now. Quote
