toTAZ Posted November 20, 2007 Report Posted November 20, 2007 hi i try to swap bytes in a word with protocol macro but i cannot find how can i do it. i use swap command in plc program and then use this buffer result in cx-protocol. buts its looking hard. is there any way to change byte order thanks.
beegee Posted November 21, 2007 Report Posted November 21, 2007 Hi, in the receive message you get the message editor, there you have the message data. If you click on the edit button you get a list to choose from: variable variable ASCII variable HEX variable reverse variable ASCII reverse variable HEX reverse I think the reverse ones just invert the bytes but I'm not sure....
