dcalderonv Posted November 22, 2007 Report Posted November 22, 2007 Hello, I have an issue with a 30 HP Micromaster 440 Drive: I need to know which are the conditions that avoid a user to modify the drive parameters, specifically the ones over 700. We havent been able to change them and we have checked the P003 which is suposed to grant privileges for modifying them. Thanks a lot for your help. Best Regards. Quote
JesperMP Posted November 23, 2007 Report Posted November 23, 2007 Apart from the access level, some parameters also require the drive to be in stop. Maybe that is the reason. Quote
