Hi ! I have GX IEC Developer 7.0 and I uploaded program from FX2N with success, but program is in IL code. How I can change it to ladder??? Thanks Pawel Edited by pszczepan
Developer and IEC Developer are completely different. I agree that it might not be an easy task, someone from Europe who's more familiar with IEC Developer should be ble to help if it can be done. I only work with GX Developer too.
You can't change it from IL directly into Ladder from GX IEC Developer. However there is a little program to do this for you though. I've uploaded the manual so you can take a look how it works. However the program might have been written in GX Developer. If it contains less than 1000 steps there is a FREE version you can download. 1009en_Ladder_Converter_GB.pdf
Hello. I use GX IEC Developer 7.00. I have followed the instructions from the manual. The program stops responding when I press the convert button. Do you have any ideas? Are there some instructions that can't be converted? Thank you.
Yes, FX1N CPU type. I also have installed GX IEC Developer 6.00. I have tried to convert using the library from 6.00 and 7.00 with the same result. In the program I use Master Control, MPS, MRD, MPP, index registers, FOR, RS and some usual instructions. Maybe it has something to do with the instructions listed above.
I have cut out from my program hoping that it will be simpler to convert but it is still not working. I have attached the cut off version of program. Thank you. FX1N_IL_convert.zip
It lookes like it's not the program it can't convert but some of the text creates a problem. I downloaded the project into a PLC did a new upload of the program so I lost the text comments. Copied the global variable list from the original project and tried to convert again. attached is the result Ouput_file.zip Edited by Gambit
