Does anyone know the pin connections so I could make a communication cable or a place to purchase a reasonably priced one. The cable kit at automation direct is $95 seems like that is to much?
does that make not ok to try some other way to get a cable just what is the purpose of this forum. You are the most negative reply person that I has ever seen.
It might help if you state which PLC you are using. Or go here: ( the info is free) http://web1.automationdirect.com/adc/Manua...og/PLC_Hardware Edited by Mickey
The pinout can be found on the Automation Direct website, somewhere :) I found it one day and made a cable with an old phone cord and it works great! Good Luck! Mark
if you did not find the pinout for one of automation direct cables here is the link http://web2.automationdirect.com/static/sp...tsoftcables.pdf good for dl05,06 105,205,d3-350 and d4-450
If you want to build DLxx cables very inexpensively (~$8)... Buy one of these RJ12 cables: http://www.l-com.com/search.aspx?q='td...9;&join=All eg TDC027-2 And buy this: http://www.l-com.com/item.aspx?id=2447 (db9-female) or http://www.l-com.com/item.aspx?id=2449 (db9-male) Then configure the plug-in pins, and you're set. That's how we make our DLxx cables at my company. Hope this helps!
