I need some help with a question. We just installed a tunnel over that bakes bagels with a wing load. The oven is run by a Compact Logix L32E, RSLogix 5000, the wing loader is run by a Micro Logix 1100, RSLogix500, and tied together via CAT5 network to a PanelView. Both are controlled by the PanelView. My question is can you send or request data from the Compact Logix to the Micro Logix? What I need the programmer to do is copy data, Recipes, store in the L32E and I need to get some of the data to the 1100. Thank you for your help, Mark
