edda Posted December 10, 2007 Report Posted December 10, 2007 Right now I´m up to replaceing a old citect application to a Beijer Panel... but i´m rather poor at citect so need help with this... Status = 0; DevFirst(hRiktverk); WHILE Status = 0 DO Recept_Börvärde_Old = strToInt(DevGetField(hRiktverk, "U")); Recept_Börvärde_New = Recept_Börvärde_Old + (Nollvärde_New - Nollvärde_Old); DevSetField(hRiktverk, "U", IntToStr(Recept_Börvärde_New)); Status = DevNext(hRiktverk); END Sure I know that it will be doing it untill Status isnt 0... but what is "Status"? I got the whole script here (11 pages)... Best Regards. //edmund Quote
PdL Posted December 10, 2007 Report Posted December 10, 2007 Look for the string "status" in the project editor > tags > variable tags form. In Cicode you can refer to Variable tag names directly. Quote
edda Posted December 10, 2007 Author Report Posted December 10, 2007 Cant find it there...its beeing declare in the top of the script (INT Status = 0;)... what about this "Status = DevNext(hRiktverk);"?? what is DevNext? Quote
tragically1969 Posted December 10, 2007 Report Posted December 10, 2007 DevNext Gets the next record in a device. If the end of the database is reached, the EOF flag is set and an error code is returned. Syntax DevNext(hDev) hDev: The device handle, returned from the DevOpen() function. The device handle identifies the table where all data on the associated device is stored. Quote
dua anjing Posted December 10, 2007 Report Posted December 10, 2007 Somewhere in your 11 pages there will be a DevOpen() this function opens a Citect device that you should be able to find in the Project Editor. The DevOpen will have a returned a handle for this device this handle is stored in hRiktverk. DevNext(hRiktverk) will step to next record in the Device. if it is successful it will return a 0 into the variable Status and will therefore remain in the loop. If it is not successfull it will return an error number and this will drop the code out of the loop. Most likely cause for it to be unsuccessful is that it reaches the end of the device BUT there could be other reasons. have a look through Citec's documentaion on error numbers. Quote
edda Posted December 11, 2007 Author Report Posted December 11, 2007 Ok but there is about 10 of this DevNext in the script are they all being process at the same time? Are citect script processed all the time or can they be trigged on a signal, I cant find what would start it anyhow... not sure how i can search after it, the citect version is 5.21... Quote
dua anjing Posted December 12, 2007 Report Posted December 12, 2007 I copied this snippet from your original code.. FUNCTION Tryckrulle1() THIS LINE IS THE BEGINNING OF THE FUNCTION. SOMEWHERE ELSE IN YOUR PROJECT THIS FUNCTION WILL BE CALLED. TRY SEARCHING FOR "Tryckrulle1()" . ONCE THIS FUNCTION HAS BEEN CALLED IT WILL RUN ONCE ONLY. Minvärde_Old = LS_sw_press_roll_1_min; //Läser in "gamla" Minvärdet. Maxvärde_Old = LS_sw_press_roll_1_max; //Läser in "gamla" Maxvärdet. Nollvärde_Old = strToInt(Z_pressure_roll_1); //Läser in "gamla" Nollvärdet. Börvärde_Old = SP_pressure_roll_1; //Läser in "gamla" Nollvärdet. Maxvärde_Temp = Maxvärde_Old - Nollvärde_Old; //Beräknar skillnad mellan 0 och Max. Minvärde_Temp = Nollvärde_Old - Minvärde_Old; //Beräknar skillnad mellan Min och 0. Nollvärde_New = PV_pressure_roll_1; //Läser in nya 0-värde från ÄR-värdet. Maxvärde_New = Maxvärde_Temp + Nollvärde_New; //Beräknar nya Maxvärdet LS_sw_press_roll_1_max = Maxvärde_New; //Läser ut det nya Maxvärdet till PLCn. Minvärde_New = Nollvärde_New - Minvärde_Temp; //Beräknar nya Minvärdet LS_sw_press_roll_1_min = Minvärde_New; //Läser ut det nya Minvärdet till PLCn. // Börvärde_New = Börvärde_Old + (Nollvärde_New - Nollvärde_Old);//Beräknar nya Börvärdet // SP_pressure_roll_1 = Börvärde_New; //Läser ut det nya Börvärdet till PLCn. Z_pressure_roll_1 = IntToStr(Nollvärde_New); Status = 0; DevFirst(hRiktverk); THE DEVICE HAS BEEN OPENED ELSEWHERE ,LOOK FOR "DevOpen(hRiktverk)" .THIS LINE ENSURES THAT WE ARE AT THE FIRST RECORD IN THE DEVICE WHILE Status = 0 DO Recept_Börvärde_Old = strToInt(DevGetField(hRiktverk, "U")); Recept_Börvärde_New = Recept_Börvärde_Old + (Nollvärde_New - Nollvärde_Old); DevSetField(hRiktverk, "U", IntToStr(Recept_Börvärde_New)); Status = DevNext(hRiktverk); ONLY WHEN WE HAVE REACHED THE LAST RECORD WILL Status <> 0 THEN WE WILL JUMP OUT OF THE LOOP END END THIS LINE IS THE END OF THE FUNCTION. ANYTHING BELOW HERE IS MOST LIKELY ANOTHER FUNCTION AND WILL ONLY BE EXCUTED WHEN THAT FUNCTION IS CALLED . I hope this explains some of what your are looking for. I have had a quick look thru your code. If you have access to Citect's Example project have a look thru their recipe demonstartion it uses similar cicode to what you have posted here . If your English is good it may help . Quote
edda Posted December 12, 2007 Author Report Posted December 12, 2007 Thank you dua anjing.... this will help me Ok I will take a look at the examples... Quote
