motioncontroller Posted December 12, 2007 Report Posted December 12, 2007 Has anyone used this product line from GE at all? It is the IC676PB series or the IC677PB etc. I am wondering about performance, pros and cons anyone has noticed. Thanks. Quote
RussB Posted December 12, 2007 Report Posted December 12, 2007 We've used it with device net, works fine, no outstanding issues or problems. Quote
motioncontroller Posted December 17, 2007 Author Report Posted December 17, 2007 I am refering to the IP67 "drop boxes" with the M12 connections on the front of them, I am really just more concerned about environmental performance. I am looking for systems that work well covered in drilling fluid...... Quote
KP_EENG Posted December 17, 2007 Report Posted December 17, 2007 They should work well in a rather harsh environment. I have used similar products in parts washing applications with various oils splashing on them and had no problems. Actually, I have seen more issues when using sensors with quick disconnects on the sensor side in these types of envrionments. I would try to stick with a sensor that has a molded cordset on the sensor side if possible. regards Quote
