sd00 Posted December 20, 2007 Report Posted December 20, 2007 Hi, I was wondering if anyone here could assist me in the setup of a Q Series PLC with a QJ71E71-100 for OPC connection via UDP. In line with the PLC being replaced, I Ideally need the new PLC to allow the existing Kepware communication settings to work. I am pretty unfamiliar with the Mitsi PLCs / GX Developer & setup so some screen shots or step by step guide of how I can set it up to allow a UDP connection on Port 263 (as set in Kepware - decimal i guess). I'd appreciate a quick response if possible. Many Thanks, Steve.
Gambit Posted December 21, 2007 Report Posted December 21, 2007 I haven't used capware yet. SO i do not know which setting they use. Remember the port nr setting in GX Developer is a Hex number.!!!! so 263 should be H107. However for UDP connections you can only start from port nr H401 - 1025. Does CAPWARE use ASCII or BIN comm. Maybe it's easier if you send the capware settings you've made. Attached are port setting which I think should work but i can;t be sure unless I see the capware settings
sd00 Posted December 22, 2007 Author Report Posted December 22, 2007 The port number can be changed in Kepware, so if need be I'll do that. I'll give it a try, thanks very much for your swift reply. Steve.
