u_alena Posted January 9, 2008 Report Posted January 9, 2008 I'm using Mitsubishi Q06HPU, I found my ZR & Z memory been fully used until ZR32767 and Z32767. I read the Q06HCPU manuals, and understand that I use it until ZR65535. But how ? I sincerely ask yours to give me some ideas beside changing the CPU. Thank you very much.
Gambit Posted January 9, 2008 Report Posted January 9, 2008 In the parameters use file register and increase the K-points. If the standard memory isn't enough use a mem-card. Before you choose your type of card check if the databook for the differences regarding fileregisters access.
u_alena Posted January 9, 2008 Author Report Posted January 9, 2008 Thank you for your advice. In the parameters, I'm using Standard RAM and I increase the file register K-points to 64k. But I still seeing my memory map showing until R3276767 point. Why ? Beside, What is block conversion ?
Gambit Posted January 9, 2008 Report Posted January 9, 2008 (edited) You probably haven't downloaded the new file to the stadard RAM yet Make sure to select whole range in the bottom of the screen. block conversion?? where do you see that? Edited January 9, 2008 by Gambit
